I talked to Diamond and for about $35 for the set
they will move the pin height if needed and other
things as well... I have chevy blanks in mine that
the valve pockets are mopar and I had some dish put
in to lower the compression a little... they will treat
you well and they have been quick.... the last set
I got took 3 days for my Rampage...but I also know
the owner
Just so you know, it's about 40.00 dollars PER CHANGE to shelf stock and you're allowed UP TO TWO CHANGES. I’m a Distributor for Diamond, Let me know if I can help.
Dan,
Didn’t they used to give you 2 free changes?
So there’s a 2 limit change for stocking numbers now?
What if I want 3 or 4 total changes?
