Skip the Chevy pistons, not only is the valve angle wrong but the valves in a Chevy aren't on center with the cylinder like the SBM.
I've had Wiseco, Diamond, and Ross pistons in the past and all are high quality and you can get exactly what you want for just a little more money over a shelf stock. Well worth it in my opinion.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost conversion. 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
