Quote: Do 400's run good ?? Well my son has run 11.40' @ 117 with his stock stroke 400. It's a mild build with stock Eddy RPM heads and the MP .557 cam.
is he using a steel 383 crank, or did he use a cast 400 crank? does it make any botton end torque, or does it like higher rpm's?
