Car is running proper and sounds great!
Had a number of problems under the hood. Changed out the valve guide seals, VC grommets, water pump gaskets, one intake valve, valve springs, spark plugs and one plug wire. Starter was weak/slow so swapped out. New PS shaft seal.
Engine was painted wrong color (orange) which I painted back to Mopar blue. Still need to get right air cleaner, new plug wires and do a lot of scrubbing. Alternator spacers are wrong, correct ones on order.
Need to do fuel lines tonight as several are in tough shape.
"I think its got a hemi"
