Every now and then I have a tense moment when one won't go in, and I KNOW it's the same parts that came out...last one I got a wood block and a 5 lb 'persuader' and used a few judicious taps on the axle center register.The outer bearing shells were a bit reluctant was what ended up to be my problem.
