Google "1994 dodge ram vacuum hose diagram". There are a few factory diagrams that will point you in the right direction.
This is going from memory- the blue connector is factory but out of position-(not sure how). The line from the throttle body is for the map sensor.
The bronze cap on the fuel rail is the fuel pressure regulator...a black plastic line 1/8" or so ties to that.
1970 Plymouth Barracuda 1994 Ram 1500 4x4 5.2L 2004 Ram 1500 4x4 5.7L Quad Cab
