I recently bought a 06 2500, automatic tranny, base model no frills old style basic key (No Fob No Chip), question is to remove key from ignition do I have to turn the key all the way back and then one click forward to remove?
Technically, Yes. All the way back should be the accessory position. In my '03 it goes Accessory-Lock(remove key)-Off(vehicle not in park would prevent you from removing key in this position)-Run-Start as the positions of the key.
But you don't have to turn it to the acc position first and then to lock to get the key out. That's why I suggested the shifter cable or interlock is not adjusted correctly.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost conversion. 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
