I recently bought a 06 2500, automatic tranny, base model no frills old style basic key (No Fob No Chip), question is to remove key from ignition do I have to turn the key all the way back and then one click forward to remove?
Technically, Yes. All the way back should be the accessory position. In my '03 it goes Accessory-Lock(remove key)-Off(vehicle not in park would prevent you from removing key in this position)-Run-Start as the positions of the key.
