I've ran several different 440 wedges, 426 Hemi and 400 with Elephant ears on the front with no midplate and a stock type trans. mount,they never cracked anywhere I've never had, seen or heard of a stock block crack like yours that wasn't frozen first
I thought the same thing,that vertical crack in particular. I have only seen vertical cracks from frost. I suppose the filler has absorbed water and/or is porus enough the expand on its own when frozen
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas 9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ! 2013 StickShift Challenge Winner@ Mopar Nationals!
