I know what you're saying, seems like no matter what you do there's wires and hoses and fuel lines everywhere. But you did make your engine bay look pretty clean in my opinion The reason I asked about the I/c is because I run my a2a in front of the radiator and my motor runs hot. Probably switching to a w2a this winter, that will help a ton I think with the overheating. Going to try to mount the I/c under the dash if I can get it to fit.
