408 smallblock F1R with a blow-thru setup and meth injection. Made 1088 at the flywheel with two bad pushrods at 6800 rpm, then the serpentine belt started to slip. Switched to a cog set-up now. In a 71 Dart 3550 lbs, stock type suspension, and drag radials. Still learning with it, best et 9.29 and best mph 148. No pics on this computer. Nothing like the set-up above
Would love to see a few pics if you get a chance. Sounds like it's working pretty good.
Brett Miller W9 cnc'd heads STR Chassis fabraction
