Re: 452 vs 906 HEADS
[Re: LaRoy Engines]
#1521429
10/24/13 10:41 PM
10/24/13 10:41 PM
Posts: 36,041 Lincoln Nebraska
RapidRobert
Circle Track
Circle Track
Lincoln Nebraska
Has anybody got any tests on an internal combustion engine, with empirical evidence, quantifing the actual effects of this 'heat wicking aluminum'? 'Cause all I can find is people saying, "Aluminum conducts heat faster, so therefore, blah, blah, blah."
Well maybe that is good enough as is. With the Stealth heads he'll have more SCR, less weight & highly likely have no danger of pinging & definitely go faster from all of that plus more flow. I have no empirical evidence as that takes edumacation EDIT OK I will withdraw what I said about wicking off heat but very likely the OP can run a set of Stealths with his combo & wont have any pinging plus the other bennies
