Re: Is there a better cam for this 505 with exhaust maifold
[Re: Teamx]
#1520087
10/20/13 06:57 PM
10/20/13 06:57 PM
Posts: 4,316 Prospect, PA
BSB67
Prospect, PA
What we have here 505 stroker Stealth Heads very mild porting (just tidy up) 10.5 comp with assembled quech at .040 Hyd roller cam with 230/230 @ .050. lift .576/.568 on 112 lobe installed with no advance Factory six pack induction Factory Hipo exhaust manifolds with twin 2 1/2 exhaust with X pipe On the engine dyno this made max TQ 575 @ 3350. Max HP 494 @ 5300 (this was with a twin 2 1/2 exhaust and mufflers hooked up)
The car: 70 Cuda auto with 2200 converter 3.23 posi with 28in tall tires Power brakes,power steering.
I know obviously a set of headers and maybe a 3in system would do wonders for this combo but the ex manifolds need to stay. The dyno operator has told the owner he is leaving some on the table with this cam chioce.
Anyone care to provide some input on this? Thanks Tim
What is the problem, or what are you trying to accomplish?
Is the car together and running?
Have you been to the track? What is the performance?
Will you go back to the dyno?
Guessing at what some of your answers might be, I would say leave it as is and take it to the track. Once you have some time driving the car, and in-car performance data, then you can get clear on what your goal is, and the guidance will be better.
