Quote: Remember that an 86 Ramcharger has a single glass bulb on each side. Lighting both elements inside that bulb will likely overheat the bulb itself as well as the plastic adjusting clips and the wire harness....
Not a good idea.
-Jim
I can fix it... my old man is a television repairman. He's got the ultimate set of tools... I can fix it.
