Quote: I don't understand all the negativity toward the engine builder contests
It’s the scoring! Taking the area under the HP curve is misleading. If you run an engine where you set the transbrake at 5000 off the line and shift at 7000-8000 then mostly what you care about is how much power you’re producing around your shift point.
I would hope they are also making allowances for engine displacement.
This post is available in double vision where drunk.
