That first picture was after taking .004 off the deck. In this one you can see more clearly where the Roloc disc dug in a little harder. Obviously the blue spots are the LOW spots.
IMO, The pics arent proving your point. I see very large Uniform Diameter impression marks of different depths in the first two pics.
Evidence of a bad hand rolex disc clean up would be less uniform and sporatic.
In your First pic, the Cylinder tops are untouched by your first shave but the deck clearly shows a wide diameter pattern impression. On the Second cut the "one cylinder" shows the same pattern of the wide diameter cutting impression that the Deck shows on the First cut.
The low/blue area at the immediate edge of the cylinders, could have been caused from too much grinding with a cookie, but those marks on the outside edges of the deck surface were made with something large in diameter..possibly an older Blockmaster with dull cutters and too fast of travel speed. ![](/ubbthreads/images/graemlins/Twocents.gif)
If you like drag racing, support your local track.
