That first picture was after taking .004 off the deck. In this one you can see more clearly where the Roloc disc dug in a little harder. Obviously the blue spots are the LOW spots.
IMO, The pics arent proving your point. I see very large Uniform Diameter impression marks of different depths in the first two pics.
Evidence of a bad hand rolex disc clean up would be less uniform and sporatic.
In your First pic, the Cylinder tops are untouched by your first shave but the deck clearly shows a wide diameter pattern impression. On the Second cut the "one cylinder" shows the same pattern of the wide diameter cutting impression that the Deck shows on the First cut.
