My 2000 Ram Sport has the riveted ball joints and I replaced them a year ago. Get a good drill and plenty of good bits because that's the only way my would budge.When you drill almost to edge of the rivet, then the air chisel will pop them out.
Yeah, that's what I wound up doing. That air chisel is gonna kill my elbow (that's been hurting for weeks now), though.
I also found where I've been losing coolant. It's a slow leak and I figured I'd go look for it soon. Well, looks like both freeze plugs behind the motor mounts are leaking and probably the rear one on each side. It looks like the front ones have already been replaced...
