I hate to bring this old thread back to life but I hit a snag on my truck that I can't find the answer to and hoping someone knows. I put the small diameter, big block brake booster on and it rides hard against the MP valve cover. I decided to go manual brakes using the 1983 master cylinder. I fabbed a cover plate from .063 stainless and need to know if this is the pushrod that will work. Nowhere can I find any dimensions for it.
http://chucker54.stores.yahoo.net/mopeadbrrodp.html
Mopar Performance Adjustable Brake Rod Pushrod
Item# MOPP4510640
$53.95
Product Description
This handy threaded brake rod is great when you adapt different master cylinders on Chrysler or Tube Chassis cars.
