The swap is easy. Any hotrodder can figure it out. Hardest part is picking the right master for pedal feel based on caliper/cylinder size.
That said, I'm running a whiplash on my 5.9. 222/228, 107 LSA installed at 104. Idles at 8".
My power brakes work fine. Check your booster for leaks
Thanks but you missed the point of my post a little bit.
