Sorry to barge in, but was wondering what "remote" turbo is.
SDS Turbo sells them. It's a turbo that mounts way back by your rear axle or gas tank. Can run a single or twins. Adds in a bunch of extra piping, and an electric oil pump to move the oil from the turbo return back to the pan. They claim to specially build their turbos to not lag excessively for being so far back from the engine. Problem with that on a mopar is, to get room, you pretty much have to yank the gas tank and put the turbos there. Then put a fuel cell in the trunk and install a bulkhead behind the rear seat so the track will let you run.
