how many threads of the adjuster are BELOW the rocker arm , I'm ASSuMEing that you used the same pushrods ...
I haven't checked that. The adjusters were set to the old setup when I installed them at first. I had to turn them CW about 1 1/2 turns to tighten up the lash. It looks like about 3-4 threads show above the lock nuts.
