We have a neutral dampener up front. OE flexplates are neutral. You've spoken with the po/builder & did as much eng checking as you can. Unless you check further & find out if it is or is not a magnum then at this point in time I'd get another neutral (non 360) LA (non magnum) converter & try it.
