The LA 360 balance weighted converters that I have seen usually look like a rectangle with the top 2 corners cut off.
Also, I have seen 360 balancers that look like the 273/318/340/383/413/440 steel crank-neutral balancers with that recessed ring EXCEPT that there is a raised section within.
