Today I put in the gauge cluster and replaced the headlight switch. I also hooked up everything under the dash (heater cables, wires, emergency brake, etc). Installed the window trim clips.
The car was a column shift but now has a floor shifter. Took a part the 4-spd column I had and painted it. Also took the ignition out of the old column and put it in the 4-spd column so the door key would match the ignition. Painted/dyed the original wheel and horn cap. Will install tomorrow. Also, will be installing the headliner tomorrow. After that I will be able to install the interior.
