I'm going to be the odd man out and say THERMOQUAD!
Really is a great carb once you learn the tricks, I'm half temped to take the pair of AFB's off my tunnel ram and swap them for TQ's.
The 800 CFM Edelbrock Thunder AVS is a fine carb and strip kits are easy to purchase.
No, I will be odd man out...I have a edelbrock/Q-Jet 750cfm thermobog replacment carb on my stock 440/RPM intake.
great carb for economy and performance, feeds the 440 with no problem,low speed throttle responce and drivabilty is as good or better than a well tuned thermobog carb.
the holley 650cfm spredbore thermobog replacment carb is a close 2nd on my stock 440.
q-jet beats it with throttle responce and mpg
Interesting choice. Didn't Mopar use Quadrajets for a few years after they gave up on the Thermoquads?
