I've had after market timing sets that have to be degreed to have the cam installed correctly, on those you can not get the dots lined up perfectly. The cam dot will not align perfectly with the crank dot, the dot will be off a tiny bit either way, not perfect One tooth on the cam gear is right at 12 degrees retarded or advanced Degree it
