Isnt the bedliner on the inside gonna get messed up when your weldung on the bottom ?
I think he's done with the cab floor.
yes, i got it done, waiting to do the rocker next,i got to chop rust out first, then chop greenie up a little more to patch the rocker.
when its all done it will get another gallon bedliner on the bottom. if you look I did the a-pillers/jambs and plan to do the lower rockers along with the floot bottom.
once thats done its on to the front drip rail/roof repair. clean/cut/weld/allmetal should fix up the weak spots and small holes. looks like i will have to trim the front driprail edge middle section out. main thing is to be able to get the pinch weld solid,glass/gasket in, then seal it up across the top of gasket with body sealer.
ran out of wire today so add another 20$ for a 100$ total for patch repair.
still ahead at 450$ for rust free cab replacment.
