a little paint to keep the flash rust down, go back and grind the welds down flat. and its patched.
do a little sand blasting on the surface rust on the rest of driver floor, then a coat of bed liner sprayed inside.
then it is ready to flip on its back so I can weld the back side of patch, then coat the firewall/cab bottom with the bed spay on bed liner.
ACE did a 59 chebby and I do like the finished look of the spray on bed liner inside and out of the cab. easy clean up with a hose and not soggy carpet.
