Hello,
Spray bar oiling is a system that was intended for cooling of the springs. It was not intended for primary oiling of the rockers. Don't expect it to work as a primary means of rocker oiling if you have high pressures.
Damon
Sure it will, and has done just that for years.
It just needs to be setup properly. Adjusters what are hollow, which allows oil to enter the cup. I prefer Cup adjusters, and ball/ball end pushrods. Many people with these rockers, have had zero problems with this setup. My self included..I ran The Jesel setup, and made my own Oiling spray bars, out of brake line etc. Ran it for years without trouble.
