The large port at the lower front of the Carb was loaded w/black crap, I shot in bunch of carb cleaner spray n scraped out the build up crud.
Zero noise last couple of days.
Make any sense? Gotta grab my rebuild kits n booklets I loaned to a buddy, i'll remove carb n thoroughly clean it.
Any further thoughts? other than it allegedly screaming "I Want a Hemi". That one was especially helpful.
sounds more like a vacuum problem maybe.. and as far as the hemi... only unless you want your wallet totally empty for no performace gain.
