Re: A518 (Diesel) 2-Pin Connector Wiring
[Re: jcc]
#1451679
06/12/13 11:56 PM
06/12/13 11:56 PM
Posts: 7,497 Minnesota
Hemi_Joel
Minnesota
Your swap is not clear to me, are you using a diesel 518 with a gas or diesel motor? And why the Ultra bell, and why a 6000 rpm converter? Its not a lock-up style?
I own a 518 diesel tranny that I will one day drop into a small block street car, and your solutions are not what i expected.
The way I read it is thus: The small block ultra bell tells us that he is putting it behind a gas motor. 6000 RPM governor, not converter. The governor controls the shift RPM. A518's use a non-lockup converter. I hope this helps, Joel
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
