You'd have to solder an appropriate thickness of feeler gauge on the back of the can on both sides of the arm to limit the notches' travel into the can to change (reduce) the total amount & likely could file the notches to add total. Using the 3/32" allen wrench doesn't change the total but changes at what vacuum level the curve starts (& therefore ends) & it's linear
