TQ,
Did you eliminate the spring isolators, or replace them with poly? Steel? Just curious, I (fortunately) don't have to worry about those critters. Also, it looks like you've got the "classic" EB's, not the red ones. Are they the same animal?
Clair
Poly isolators, grey shocks are purportedly a little less stiff than the reds, reds in the front [chebby shocks]
