Ladder bars, super simple and hooks in a car wash...4-links are a pain. Also, its likely a 4-link will have the coil overs protrude thru the bed...
your truck is one of my favorite d series trucks ive seen. did you eliminate the leafs? id love to see some more pictures of your setup. what brand coil overs did you use? did you buy a ladder bar kit or did you make it yourself?
im wanting to eliminate the leafs due to them being junk. plus im planning to lower
Just an aftermarket set-up. I do not recall what brand, but I will look under it. No leafs. Rides and drives better than my diesel and nothing protrudes thru the bed.
