The Rebel Wiring harness is pretty much the same as the factory except for ther wire colors. The "alternator exciter" wire is probably the same as the factory blue wire...it is powered only when the switch is in the RUN position; the "accessory bus" (?) plays no part in the charging system.
The INTERNET, the MISinformation superhighway
