So i purchased a wiring harness from rebel wiring.
If your harness has a blue and a green field wire(s) with the female connectors plug them into both of the alt field terminals in either order & you're set. If that harness only has a green field wire (pre '70 harness) then plug it into either alt field terminal & ground the other alt field terminal to the alt case & with the large black charge wire with the ring terminal connected to the alt "batt" stud you are all set
