Oops ive been useing alu fuel line for several years now.
And I've just bought alu fuel lines to install for my E85 street engine.
Research papers say E85 has very little impact on aluminium, so I don't expect any problems.
Its not the E-85... its the water it absorbs... water
on alum will corrode ... even the coated alum line
due to the fact that when you bend the line you crack
the coating which exposes the alum
