Thank you for the reply. This is a high dollar Ray Barton hemi built about 10 years ago, with approx. 4k miles on it. It's set up right, just has a lot of crankcase pressure when it's wound up. I'm going to start with breather mods first and see if that helps. Previous owner who built the car said he had luck just keeping the breathers clean, so I plan to start there.
