Yes, I ran into the same problem quite a few years ago. I took a dremel with a grinding bit and I went around the inside of the crank until the converter hub fit fairly snug. Never had any balance issues or problems from doing that way. I know it is NOT the way to do it but I was taking a shot at it anyways.
