Quote: RR, the only reason you want bare heads is so you can use those 3/8" stem valves you have lying around. correct. Time to move on! cant, budget constraints. 5/16 or 8mm stems have much less mass and don't block the airflow as much. I agree but on this street app I'll be fine .
