paironines, does it knock if you have the vacuum advance disconnected?
Also, you turn the adjustement screw counter clockwise to to move the vacuum required to stroke the pod up and clockwise to move it down.
What is you initial timing set at, what the total mechanical and what rpm is it all in at?
Dave Clement Pembroke, MA 03 PT Cruiser GT Turbo 99 Dakota SLT+ CC 4x4 68 Barracuda sport coupe http://home.comcast.net/~dgc333/
