Dcuda69, 50-52 degrees is just about where you want to be when you add up all the numbers. The engine will very seldom be at 50.
The small block MP distributor i just set-up a couple of weeks ago had a vacuum pod that would add 17 degrees of timing at full stroke and was adjusted so it started coming in at 9" Hg and was all in at 18" Hg.
Dave Clement Pembroke, MA 03 PT Cruiser GT Turbo 99 Dakota SLT+ CC 4x4 68 Barracuda sport coupe http://home.comcast.net/~dgc333/
