maybe u just have too much total. the adj vac thing is misleading. you can't adj how much. u can only adj. how much vac it takes to pull it in. they are pre set. take the # on the the arm and double it thats how much it pulls in when it sees the vac. u adj. it for. some say epoxy a piece of metal on the arm to stop it for the amount you want pulled in.
65 Cuda 360,3.23 SG-13.97 @99.4, 88 D100, 2000 Kota Qcab, 71 Duster 416 11.84 @110., 73 Imp ,(2)72 & (1)71 Dart Swingers GarysMocars Legendary Dealer
