Re: Building a curvy car
[Re: joshking440]
#1398437
03/07/13 11:21 PM
03/07/13 11:21 PM
Posts: 5,394 Pikes Peak Country
TC@HP2
Pikes Peak Country
No Sanctioning body, no real plans.
I want a car I can drive from Indy to Vegas at 200mph if I want to.
Ride good handle good do donuts good.... just an all around real fun car
Well shoot, all you really need is some big fat tires, massive brakes, Fox shocks, and wrist thick sway bars. You're set, hit it!
In all seriousness though, you might want a Morrison Max G full frame conversion for simplicity. They even have them for A bodies. With all that big block weight on the nose, You'll need to converse with these guys, and your buddies maybe, about the correct roll couple percentages to keep things manageable so the shiny side stays up.
200 mph, hmm, maybe for a split second on a run but not for any duration in a stock body Cuda. If your willing to cut and mod the bod, maybe then you could sustain it.
