You can't always determine if a driver is babying the car or abusing it from still pictures. Expecialy those that you posted because of where the car is on track/in the corner/coming out of the corner, shortchutes between corners as the car isn't leaning over and the tires aren't scrubbing the edges or sides. I'm hoping you have a vid or 3 that you could post, hint hint.
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
