Re: Oil pan drain bolt fubared...options, pls?
[Re: hp383]
#1393452
02/27/13 09:57 PM
02/27/13 09:57 PM
Posts: 1,357 central Florida
VL21
central Florida
Use a small pipe wrench or grind/file a couple flat spots and give it a go again.
I have a wrench I found in a junker, it has a movable,spring loaded jaw, works sort of like a pipe wrench, the harder you pull the tighter it gets ... if there is any amount sticking out from the pan face, I am sure this thing would get it.
Is it the Magic Wrench?
It is a Weil, 10" version. At one time I had a larger one, lost it. Custom imported from afar. Japan It has saved me several times, and taken a beating. Glad I have it. Goes to the upull everytime now. Has replaced my small pipe wrench. I recently found another, much cheesier, sort of looks like something would come in a bicycle tool kit, works on the same principle.
It takes gasoline to interest me.
Entire Thread
rnch
02/25/13 08:53 PM
340SHORTY
02/25/13 09:29 PM
scratchnfotraction
02/25/13 09:47 PM
tmef
02/26/13 12:48 AM
dOc !
02/26/13 01:17 AM
340SHORTY
02/26/13 01:29 AM
poorboy
02/26/13 03:33 AM
dOc !
02/26/13 04:01 AM
rnch
02/26/13 06:32 AM
360view
02/26/13 12:08 PM
76dodgeboy
02/27/13 12:00 AM
VL21
02/27/13 02:55 AM
hp383
02/27/13 04:06 AM
VL21
02/28/13 01:57 AM
rickstershemi
02/28/13 04:07 AM
therocks
02/28/13 12:15 PM
