Oil pan drain bolt fubared...options, pls? #1393439
02/25/13 04:53 PM
02/25/13 04:53 PM
Louisiana
rnch Offline OP
rnch  Offline OP
Louisiana
I FINALLY got around to doing an oil change on my new (for me, anyway) '85 pick up, 318 engine. It needed it!! The oil was thick & filthy.
After crawking under the truck, I discovered why the oil was so dirty.
The oil pan drain bolt is ALL buggered up, rounded off, and quite solidly stuck.
Any/all wrenches and vice grips I can find will not budge this stuck, rounded off bolt.
What are my options here?
Can I center punch it into the pan,tap and thread an oversized one? If so, will the partial bolt inside the oil pan make some trouble?
Or should I find a used oil pan and swap it out?
Your thoughts and opinions, please.
Re: Oil pan drain bolt fubared...options, pls? [Re: rnch] #1393440
02/25/13 05:29 PM
02/25/13 05:29 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
If your good with a drill do it and tap it for a 1/8 (IIRC) plug.
I am truckless..
Re: Oil pan drain bolt fubared...options, pls? [Re: 340SHORTY] #1393441
02/25/13 05:47 PM
02/25/13 05:47 PM
scratchnfotraction Offline
find a big nut that the rounded off part of drain plug fits into then plug weld them together. the heat should help unstick the plug so it can back out and be reused...just a big azz wrench/socket is needed next time.
no on the pan or pulg as it is only a thin nut tack weld to the inside of pan.
they make re-threder plug for drain hole repair when the threds are shot but of no help for you at the moment. you are just stuck and rounded off.
if no welder the try a lot of heat and spay it with blaster to cool it down,that should suck some blaster into it to free up the threds.
good luck
Re: Oil pan drain bolt fubared...options, pls? [Re: rnch] #1393442
02/25/13 08:48 PM
02/25/13 08:48 PM
Wichita, KS
tmef Offline
tmef  Offline
Wichita, KS
Look at Irwin Tools, Bolt Grip Extractors. Saved me many times.
Re: Oil pan drain bolt fubared...options, pls? [Re: tmef] #1393443
02/25/13 09:17 PM
02/25/13 09:17 PM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
B I G G E R vise-grips ! ...post a pic on how it is buggered-up ...
Re: Oil pan drain bolt fubared...options, pls? [Re: dOc !] #1393444
02/25/13 09:29 PM
02/25/13 09:29 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
LOL Scratchy wants to "SPAY" it..
I am truckless..
Re: Oil pan drain bolt fubared...options, pls? [Re: 340SHORTY] #1393445
02/25/13 11:33 PM
02/25/13 11:33 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
If the oil is really nasty, I would be a little concerned about putting much heat on the pan, I've seen the oil inside of them start burning, not pretty!
I would plan on replacing the pan, likely, if the drain plug is in that tight, it will break the thread nut loose inside the pan when it comes loose, or as your trying to repair the threads.
Good luck. Gene
Re: Oil pan drain bolt fubared...options, pls? [Re: poorboy] #1393446
02/26/13 12:01 AM
02/26/13 12:01 AM
Florida STAYcation
dOc ! Offline
dOc !  Offline
Florida STAYcation
Nasty and GASSY .... could not only burn ... but Xplode
Re: Oil pan drain bolt fubared...options, pls? [Re: dOc !] #1393447
02/26/13 02:32 AM
02/26/13 02:32 AM
Louisiana
rnch Offline OP
rnch  Offline OP
Louisiana
anyone have a 318 oil pan for sale? IDK what it looks like; as long as it's leak free and the drain bolt is NO stuck......
Re: Oil pan drain bolt fubared...options, pls? [Re: tmef] #1393448
02/26/13 08:08 AM
02/26/13 08:08 AM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
bolt grip extractors,
run the engine to warm the oil
warm the female threads of the tack welded nut further with one or two soldering irons held against it on either side,
but chill the rounded off bolt head with either a chunk of dry ice, or this
http://www.amazon.com/CRC-05002-Freeze-Off-Super-Penetrant/dp/B000TFTH00
if you cant locally find the Freeze off spray
or dry ice ( call supermarkets or welding supplies)
then go to the drugstores and get the wart freezing kits
if any friends work at science departments at universities ask if they can bring you a thermos jug of liquid nitrogen
hot female threads + chilled male threads + grip extractor sockets
Re: Oil pan drain bolt fubared...options, pls? [Re: 360view] #1393449
02/26/13 08:00 PM
02/26/13 08:00 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Use a small pipe wrench or grind/file a couple flat spots and give it a go again.
Re: Oil pan drain bolt fubared...options, pls? [Re: 76dodgeboy] #1393450
02/26/13 10:55 PM
02/26/13 10:55 PM
central Florida
VL21 Offline
VL21  Offline
central Florida
I have a wrench I found in a junker, it has a movable,spring loaded jaw, works sort of like a pipe wrench, the harder you pull the tighter it gets ... if there is any amount sticking out from the pan face, I am sure this thing would get it.
It takes gasoline to interest me.
Re: Oil pan drain bolt fubared...options, pls? [Re: VL21] #1393451
02/27/13 12:06 AM
02/27/13 12:06 AM
State of Confusion
hp383 Offline
Just a normal tag again
hp383  Offline
State of Confusion
Is it the Magic Wrench?
http://www.youtube.com/watch?v=2YunlTrBjYI
I have (or had) one similar to this that came in really handy for trailer balls, and other large, or odd shaped items. It would grip better than a vice grip, and still allowed a ratcheting type action for loosening or tightening.
Join the Penguin Liberation Front!!
Stop the Hippo Occupation!
Re: Oil pan drain bolt fubared...options, pls? [Re: hp383] #1393452
02/27/13 09:57 PM
02/27/13 09:57 PM
central Florida
VL21 Offline
VL21  Offline
central Florida
It is a Weil, 10" version. At one time I had a larger one, lost it. Custom imported from afar.
Japan
It has saved me several times, and taken a beating. Glad I have it. Goes to the upull everytime now.
Has replaced my small pipe wrench.
I recently found another, much cheesier, sort of looks like something would come in a bicycle tool kit, works on the same principle.
Re: Oil pan drain bolt fubared...options, pls? [Re: VL21] #1393453
02/28/13 12:07 AM
02/28/13 12:07 AM
Lehigh Acres, Florida
rickstershemi Offline
Japan
you can pick up a more rugged and telescoping version at Home Depot in the plumbing tools section....used for faucets....use mine all the time....nice piece
Mikes take on welding a large nut to the existing bolt is by far the best way IMHO....been there done that....it WORKS
Rickster
Re: Oil pan drain bolt fubared...options, pls? [Re: VL21] #1393454
02/28/13 08:15 AM
02/28/13 08:15 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
VL I have one of those also.Mines probally 40 years old.I dont use it a lot but when I do its worth its weight in gold.Some drins Ive removed by using a chisel and hammer.Get it on the flat by the nut head and try to get it off.Sometimes if you try tighting it a bit they will break losse.Rocky
Chrysler Firepower
