Oil pan drain bolt fubared...options, pls?
#1393439
02/25/13 04:53 PM
02/25/13 04:53 PM
Posts: 77 Louisiana
rnch
Louisiana
I FINALLY got around to doing an oil change on my new (for me, anyway) '85 pick up, 318 engine. It needed it!! The oil was thick & filthy. After crawking under the truck, I discovered why the oil was so dirty. The oil pan drain bolt is ALL buggered up, rounded off, and quite solidly stuck. Any/all wrenches and vice grips I can find will not budge this stuck, rounded off bolt. What are my options here? Can I center punch it into the pan,tap and thread an oversized one? If so, will the partial bolt inside the oil pan make some trouble? Or should I find a used oil pan and swap it out? Your thoughts and opinions, please.
Re: Oil pan drain bolt fubared...options, pls?
[Re: rnch]
#1393440
02/25/13 05:29 PM
02/25/13 05:29 PM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
If your good with a drill do it and tap it for a 1/8 (IIRC) plug.
I am truckless..
[Re: 340SHORTY]
#1393441
02/25/13 05:47 PM
02/25/13 05:47 PM
Posts: 15,487 Florida
scratchnfotraction
find a big nut that the rounded off part of drain plug fits into then plug weld them together. the heat should help unstick the plug so it can back out and be reused...just a big azz wrench/socket is needed next time. no on the pan or pulg as it is only a thin nut tack weld to the inside of pan. they make re-threder plug for drain hole repair when the threds are shot but of no help for you at the moment. you are just stuck and rounded off. if no welder the try a lot of heat and spay it with blaster to cool it down,that should suck some blaster into it to free up the threds. good luck
[Re: 340SHORTY]
#1393445
02/25/13 11:33 PM
02/25/13 11:33 PM
Posts: 10,538 Freeport IL USA
poorboy
Freeport IL USA
If the oil is really nasty, I would be a little concerned about putting much heat on the pan, I've seen the oil inside of them start burning, not pretty!
I would plan on replacing the pan, likely, if the drain plug is in that tight, it will break the thread nut loose inside the pan when it comes loose, or as your trying to repair the threads. Good luck. Gene
[Re: tmef]
#1393448
02/26/13 08:08 AM
02/26/13 08:08 AM
Posts: 8,162 USA
360view
Moparts resident spammer
USA
bolt grip extractors, run the engine to warm the oil warm the female threads of the tack welded nut further with one or two soldering irons held against it on either side, but chill the rounded off bolt head with either a chunk of dry ice, or this http://www.amazon.com/CRC-05002-Freeze-Off-Super-Penetrant/dp/B000TFTH00if you cant locally find the Freeze off spray or dry ice ( call supermarkets or welding supplies) then go to the drugstores and get the wart freezing kits if any friends work at science departments at universities ask if they can bring you a thermos jug of liquid nitrogen hot female threads + chilled male threads + grip extractor sockets
[Re: VL21]
#1393451
02/27/13 12:06 AM
02/27/13 12:06 AM
Posts: 12,043 State of Confusion
hp383
Just a normal tag again
State of Confusion
Use a small pipe wrench or grind/file a couple flat spots and give it a go again.
I have a wrench I found in a junker, it has a movable,spring loaded jaw, works sort of like a pipe wrench, the harder you pull the tighter it gets ... if there is any amount sticking out from the pan face, I am sure this thing would get it.
Is it the Magic Wrench?
http://www.youtube.com/watch?v=2YunlTrBjYI
I have (or had) one similar to this that came in really handy for trailer balls, and other large, or odd shaped items. It would grip better than a vice grip, and still allowed a ratcheting type action for loosening or tightening.
Join the Penguin Liberation Front!! Stop the Hippo Occupation!
[Re: hp383]
#1393452
02/27/13 09:57 PM
02/27/13 09:57 PM
Posts: 1,357 central Florida
VL21
central Florida
It is a Weil, 10" version. At one time I had a larger one, lost it. Custom imported from afar. Japan It has saved me several times, and taken a beating. Glad I have it. Goes to the upull everytime now. Has replaced my small pipe wrench. I recently found another, much cheesier, sort of looks like something would come in a bicycle tool kit, works on the same principle.
It takes gasoline to interest me.
[Re: VL21]
#1393453
02/28/13 12:07 AM
02/28/13 12:07 AM
Posts: 9,366 Lehigh Acres, Florida
rickstershemi
you can pick up a more rugged and telescoping version at Home Depot in the plumbing tools section....used for faucets....use mine all the time....nice piece
Mikes take on welding a large nut to the existing bolt is by far the best way IMHO....been there done that....it WORKS
Rickster
[Re: VL21]
#1393454
02/28/13 08:15 AM
02/28/13 08:15 AM
Posts: 21,065 Niles , Ohio
therocks
Niles , Ohio
VL I have one of those also.Mines probally 40 years old.I dont use it a lot but when I do its worth its weight in gold.Some drins Ive removed by using a chisel and hammer.Get it on the flat by the nut head and try to get it off.Sometimes if you try tighting it a bit they will break losse.Rocky
Chrysler Firepower
