It will be a lot easier doing it on a engine out of the car than in, when I did mine , the car was on a lift and still took awhile . For those of you that are doing the alignment in the car you'll need a crows foot to turn the RobbMc dowel as it is a 2 flat and you can't get your hand up between the floor and bell housing.
it's ok to butt heads, just don't do it with a butthead
